280zx - New Motor but has issue cold start - Please help
New to the site? Say hello here!
healthybuddha
Post by healthybuddha » Tue Jan 17, 2017 1:55 pm
hello, i have a 280zx that i have owned for 25 years
i just had the motor done up and it does not cold start
it is as if the airflow meter is not working
first start hard to keep going
2nd start hard to put more than 2000 revs on it
3 start i have to play with throttle and warm it up b4 i drive ?
please help
you can contact me at stevenpotts etc
Post by BRONZEE » Tue Jan 17, 2017 7:27 pm
Looks pretty tidy.
= Lots of events, check out events page or our Z Club NZ Facebook page =
DKNWSZX
Post by DKNWSZX » Tue Jan 17, 2017 7:44 pm
The problem seems temp related so it may pay to check temp related items:
-CHTS
-Air Regulator
-Cold Start Valve
-Air Intake Temp
OASN (on a side note)
- What is the timing at?
- What is the fuel pressure?
Air flow metre..? How is that? Also electrical connections how are they....?
May pay to look at particular connections on the cold start injector as well as the air regulator connection. My uncle had some similar issues with his vehicle.
Regards
Deano.
Good things are worth waiting for, but great things happen at once.
Post by bernjean » Wed Jan 18, 2017 7:43 am
Do what i did, Got my fuel injection upgraded by Hi Tech Automotive. Basically got rid of the old outdated fuel injection system, Shaved the intake manifold and had it coated, New good quality injectors link computer system, used the current distributor, is an electronic type. Made a huge difference in power and drive ability. No cold start, doesn't need it. Starts first pop all the time.
reliablejunkie
Post by reliablejunkie » Wed Jan 18, 2017 10:11 am
I agree with bernjean, I took the time to make a complete wiring loom and my L20ET engine is running from a megasquirt ECU. Best upgrade I have made with this car. I have used the existing coolant sensor and the distributor and put an air intake temp sensor in the manifold. Also all the safety features like rev limiter and over boosting protection etc etc.
Someone had to make up for all the pollutants these hybrid cars are saving these days, so i cranked up the fuel pressure and let the engine roar.
1983 280ZX L20ET engine with an N42 head running on megasquirt ECU
