For sale : L28 engine and other bits - Wellington
Things, for sale and wanted - descriptive topics
Moderators: Andy, BRONZEE
kicker
Post by kicker » Sun Mar 10, 2019 5:36 pm
L28
n42 head, f54 block
Comes with
New full gasket kit
New factory rear main seal and strip seals
New factory thermostat
New factory oil pressure switch
New valve stem seals
New pilot bush
2x distributors
EFI intake manifold (off different engine)
Looking for $500 for the lot
LD28 crank $250
LD28 gearbox bellhousing, fits on a F5W71C gearbox (has the larger shift rod hole) and bolts to L series engines. $50
F5W71C gearbox from S14, housings split to test fit above bellhousing, will need a new tail shaft bearing (as I removed it) so $100, nothing wrong with box beforehand that I know of.
Jeremy
old_datto_fan
Re: For sale : L28 engine and other bits - Wellington
Post by old_datto_fan » Sun Mar 10, 2019 6:31 pm
PM sent re the engine.
Flauski
Post by Flauski » Fri Mar 15, 2019 1:36 am
PM sent
MBlades
Post by MBlades » Sat Apr 27, 2019 7:36 am
What u got left mate ?
beeto
Post by beeto » Sun May 05, 2019 8:58 pm
Also interested in what is left :)
